Currently, the "creo_parametric_admin_customization.ui" file (replacement for global config.win file) can only be read into Creo Parametric 2.0 if it is located in “Common Files\ ... \text” folder (loadpoint sub-folder). Product idea is to provide the ability to place the "creo_parametric_admin_customization.ui" file for CAD administrator UI settings in a non-loadpoint (non-installation path) folder location where it will be read into Creo Parametric 2.0. This way when a global UI change is made, the Creo Parametric 2.0 loadpoint does not have to be modified.
