Our large assemblies in Pro-E often include shrink-wrap objects of supplier assemblies like engines, transmissions and aftertreatment devices. When looking at these large assemblies in Creo View, we have to toggle on "construction surface geometry" to see these objects treated as Model Geometry in our Pro-E assemblies. I'm proposing PTC add a publishing option in the Recipe file to have shrink-wrap geometry published as Model Geometry.
The two images below show the issue with the settings. I need a solution that shows the aftertreatment device(shrink-wrap) without seeing the red construction surfaces in the floor(items circled). Also Reference PTC case 11068618.
