Quality Information Framework (QIF) export from Creo Parametric
This is an enhancement request to support the export of QIF files from Creo Parametric.
We typically use STEP or some other type of neutral file to feed our downstream processes.  Those formats do work, but looking forward we think the QIF format may provide some additional benefits because it's XML-based.  Computers love to read XML.
As of this date, we are on Creo Parametric 4, but I still have not seen any mention of QIF export up through Creo Parametric 7.  Maybe PTC can comment if they have a plan.
Now, this may suggestion may already exist.  I did do a few different searches on PTC Community, but didn't see anything.
Keith
PS for those sharp-eyed folks out there, I mistakenly created a "topic" first and not an "idea."  So, you may see both.  This is the "idea" that I'd like PTC to look at.
6 Comments
Chris3
20-Turquoise
PTC is aware of the standard and they are aware that users want it but as far as I am aware there is no current roadmap to implement it. For the time being, PTC is supporting AP242. AP242 is talking about incorporating some of the same features that you get with QIF although the step committee is not a quick moving one.
cgourru-2
8-Gravel
Here another post on same topic: https://community.ptc.com/t5/Data-Exchange/Import-QIF/m-p/550413/highlight/true#M5953
It should be integrated in the PTC roadmap
cgourru-2
8-Gravel
I do not understand why QIF is not supported by PTC.
QIF is an ANSI standard and since August 2020 recognize by International Standards Organization (ISO 23952:2020)
It should be supported by PTC, as it by Dassault System, AutoDesk, and all other competitors
JoshuaHouser
It is long past-due to implement QIF export from Creo.
Mfridman
mfischer
18-Opal
Hi all,
I have the support QIF on my roadmap for Creo, but do not have a defined plan on when it might be available natively within Creo.  Until it is supported by PTC, it is recommended that companies review the QIF export offered by Capvidia through their MBDConnect plugin.
Export to 3D CAD Neutral File | MBDConnect for Creo | Capvidia
Mark Fischer
Sr. Director, CAD Product Management
