REX enhancement - point colors
Currently on can import *.pts files which contain XYZ point location data. Product idea is to expand this functionality with point color RGB data.
This kind of functionality exist with competing CAD platforms. The main use case is a retrofits, where one has massive point clouds from industrial/bulding and then points are used as visual refrence - instead of reverse engineer process supported today.
5 Comments
MikkoHinkkanen
Like this sample
TJ_8978603
1-Newbie
This would be a very nice feature to have.
MikkoHinkkanen
Then, surely the technology like Reality Capture or similar embedded in Creo Parametric would really make magic happen. Should this also work with KeyShot then youll really would reach new hights.
https://www.capturingreality.com/
https://m.youtube.com/watch?v=i8AdX6OCvHg
MikkoHinkkanen
  1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
    Mechanical Engineering community: industrial designers, reverse engineering, retrofit designers
  2. What version of Creo Parametric are you currently running?
    Creo Parametric 8
  3. 3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
    Currently Creo Parametric has reverse engineering extension, which is outdated on functionality.
  4. What is the use case for your organization?
    Ability to generate 3D surroundings from images, video or laser scanned data.
  5. 5. What business value would your suggestion represent for your organization?
    Time to market. Product quality.
olivierlp
Community Manager
Thank you @MikkoHinkkanen for the information provided.
