In Creo Parametric 2, the grab points for dimension leaders, extension lines, and elbows were removed.
This requires the user to right click and select flip text to move the shoulder position. If one wants to remove the shoulder, the user has to set the detail option, in each drawing, default_dim_elbows to "no" and then go into properties and select a different display style for every dimension. Unfortunately, this also breaks the diameter dimensions and the user must manually set all of those as well. So, what we used to do before in one click takes at least 2 and up to 10 in Creo P2. </sarcasm> Wow, what a great enhancement to productivity! </sarcasm>
PTC tech support says that this is the way it is supposed to work and will not acknowledge that this is a bug. >_<
PTC, please bring back the grab points on dimensions so we can get back to the productivity we had in pre Creo products.
