Real to String in Relations
I would like to have a Real to String function in relations. Our company standard defines the display of the dimensions of a part as a string parameter in our BOM;
T=6.35 100x500
In order to get this currently I have to write a very complex relation to extract the values from the models;
IF MODEL_THICKNESS < 10
TK=ITOS(MODEL_THICKNESS*100)
DIMENSION="T= "+ EXTRACT(TK,1,1) + "." + EXTRACT(TK,2,2) + " X " + ITOS(MODEL_WIDTH) + " X " + ITOS(MODEL_LENGTH)
ENDIF
IF MODEL_THICKNESS >= 10
TK = ITOS(MODEL_THICKNESS*100)
DIMENSION="T= "+ EXTRACT(TK,1,2) + "." + EXTRACT(TK,3,2) + " X " + ITOS(MODEL_WIDTH) + " X " + ITOS(MODEL_LENGTH)
ENDIF
Luckily we display our dimensions in mm, so I only have to support the imperial thickness of the materials.
10 Comments
DavorGranic
Alexandrite
Same problem here. Too many lines of relations to get the same result.
James62
Granite
Rtos function would be a huge timesaver for starters.
We developed a "real to string" function for relations with Pro/TOOLKIT.
Only some 10 or 20 lines of code were necessary to realize this.
@ PTC: It's so easy, why we're still waiting for that?!
RaymonDavies
Regular Member
Not sure why we're waiting, as you said this should be a very simple request. I opened a request for this back in.... I would say 2004. It seems things have changed from their side, I don't see it in the SPR anymore.
jkent
Visitor
We ended up using JLink to create our real to string function.
fgermain
Bedrock
We are in the same case
We use relation:
     rtos_param=itos(floor(param))+"."+extract(itos((1+(param-floor(param)))*10000),2,3)
if param=2.05 rtos_param returns 2.050
for 4 digits after comma, use
     rtos_param=itos(floor(param))+"."+extract(itos((1+(param-floor(param)))*10000),2,4)
if param=2.05 rtos_param returns 2.0500
TomU
Emerald II
Here is my three decimal place version.  This includes automatic rounding.  X is the real number and Y is the string.
/* String Output - No Leading Zero, Three Decimal Places
Y = ITOS(FLOOR(X+.0005))+"."+EXTRACT(ITOS(((FLOOR((X+.0005),3))-FLOOR(FLOOR((X+.0005),3))+1)*1000),2,3)
Other versions are available here: Converting Real Numbers to Strings
psobejko
Amethyst
Wow.  Still shaking my head about this one.
Keep voting Does PTC ever read these?
PTCModerator
Emeritus
Jaime_Lee
Community Manager
T=6.35 100x500
ENDIF
ENDIF
