There are a lot of situations where you want to select an edge to blend, but do not want to use the "Chain" option. In the example below, only the blue edge is to be blended, but the blend intersection on the left should be recalculated. With "Chain" off, the "Affected Control" is set to "Auto", but the adjacent blends are not set to be recalculated.
The default with "Auto" for "Affected Control" should be to recalculate the blends at that corner.
