Recent files list workspace sensitive.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders. Mechanical engineer in consumer electronics manufacturer.
2. What version of Creo Parametric are you currently running? Creo 7
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
It would be great if the recent files list in the file tab would be context sensitive to the current workspace. So that when you change workspaces, the list changes to the most recent files you worked on WITHIN that workspace. Then, when you're jumping around between projects, you can just open the first file in the list. Helpful when you've opened so many files in a workspace(s) that the most recent from the current (desired) workspace is no longer in the list.
4. What is the use case for your organization? We have many concurrent, active projects, and shifting between them could be easier if the application remembers current workflow.
5. What business value would your suggestion represent for your organization? It would streamline transitions when moving between projects, improving speed and reducing time and cost.
1 Comment
olivierlp
Community Manager
Hello @HBalch and welcome to the Community,
Thank you for your idea and the information provided.
