Reduce mouse right click menu lag
Reduce the time required to hold the right mouse button down for the menu to pop up. Currently you have to hold the right mouse button down for a certain time for the menu to appear, while the new quick menu pops up with a quick click. Make the right mouse click work like the quick menu, where a simple click (hot click and hold) will pop up the right-click menu. 8A660017-B2D6-4F43-8617-77BD8127EE00.GIF
2 Comments
Sapphire II
I'm pretty sure they require the delay due to the existing query select functionality of the RMB. This change would disrupt my workflow significantly.
Participant
Ah, true! Maybe using a method of hovering the cursor over geometry while holding shift or ctrl and using the scroll wheel to cycle/query geometry would be better, then the right click could be instantaneous.
