Reduce mouse right click menu lag
Reduce the time required to hold the right mouse button down for the menu to pop up. Currently you have to hold the right mouse button down for a certain time for the menu to appear, while the new quick menu pops up with a quick click. Make the right mouse click work like the quick menu, where a simple click (hot click and hold) will pop up the right-click menu. 8A660017-B2D6-4F43-8617-77BD8127EE00.GIF
4 Comments
StephenW
23-Emerald II
I'm pretty sure they require the delay due to the existing query select functionality of the RMB. This change would disrupt my workflow significantly.
Ivan_
6-Contributor
Ah, true! Maybe using a method of hovering the cursor over geometry while holding shift or ctrl and using the scroll wheel to cycle/query geometry would be better, then the right click could be instantaneous.
wilwrk4tls
7-Bedrock
This should, at the VERY least, be a config option to have the query or the quick menu be the long click.  I need the regular right click (not query select) infinitely more times a day and CANNOT believe that any software company would think that a right-click menu, which is used hundreds of time a day (if not hour), would be a good choice to be on a delay, especially when it doesn't work that way in ANY other mouse-based software.
Maybe they considered it an "innovation", but for it to not be a config option to decide which one is which is an epic fail.
olivierlp
Community Manager
Status changed to: Archived
