Reduce the number of calls Creo Parametric Makes to the Windchill Server when Opening Simplified Reps
config rep_w_rule_optimize_download to work better with non-master reps.
Opening a simplfied rep of an assembly in 2009 in WF5 opened in 210 seconds.  (We had a case open and the number of calls was identified as the main contributor.
Now in Creo Parametric 2 in 2014, the same assembly and rep opens in 300 seconds.
This idea is asking for Creo to more efficiently create the packages to download into the users workspace when opening objects not currently in the workspace.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
