Reduce time or allow skip of "Integrated Mode Error Checking" for large models
0 Kudos
I create large machine level models with an enormous number of connections. The "Integrated Mode Error Checking" step takes about as long as the remainder of the run in some cases. I would like to either make this algorithm much more efficient or offer a lighter version of this check that performs only what is absolutely necessary for the solution to kick off. I'm 100% OK with the run failing later when it gets into the solution without providing much diagnostic information as I'm used to that having worked with Mechanica for many years.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
