In creo , we unable to take datum feature from parametrically prepared 3D model to 2D drawing.
Or we are unable to select planes/ Centerlines As datum feature in drawing mode.
will anyone help how could we annotate a plane / centerline as a datum in drawing?
I tried multiple times to create datum on plane / centerlines. But its not possibly done.
Rather than that on surfaces its creating datums which is not good (because surfaces having drafts/tooling operations)
As Creo is parametric software it should have this kind of flexibility to generate datums on mid plane/ planes/ centerlines to annotate the drawing with minimal dimensions
