Regarding SPR2831087
0 Kudos
We would like to know why SPR 2831087 has not been addressed by PTC till date  same problem has been faced by us &one of our componment got rejected( cost of component is around 10lakh). due to his  we had failed in meeting customer delevery shedule  hence PTC has to take it on priority resolve the issue. refer attachment for details.
case has been raised 13506256
5 Comments
Chris3
20-Turquoise
Link to SPR:
https://support.ptc.com/appserver/cs/view/spr.jsp?n=2831087
Title of SPR: How to restrict Pro/ENGINEER not to use existing detailed view name for another detail view in drawing
SRIKANTH CHANDRASHEKAR‌ you might want to vote on your own idea.
StephenW
23-Emerald II
There is a discussion Re: Creo Parametric 2.0 M130,is allowed to create detail views with same name in the drawing. This h...
According to PTC, they have a valid use case for this functionality, but details were not disclosed.
mender
6-Contributor
This is (being) implemented, see copied from the discussion noted below.  I'll ask someone to mark this idea appropriately.
For reference, the use cases we have been given by customers include using a drawing program to show one or another flavor of 'Detail A', and also having a multi-sheet drawing with one sheet for each instance of a family table of parts, each of which can have its own Detail A.  (Maybe others?  It was a numbe rof years ago...)  Whether or not this is reasonable is a question for debate.  However, PM has agreed that it should be considered non-standard, and so I have been authorized to improve matters, as follows:
In Creo 2 M250, Creo 3 M130, and Creo 4 M010, there will be a new config option 'allow_duplicate_view_names yes/NO'.  When set to yes, no change from previous builds.  When set to no, we will reject attempts to rename a view to duplicate another, and also will check on retrieval and regen draft for current duplication and give a warning.  All messages will note the sheet number of the duplicate view and mention the config option by name.
Thank you for raising this issue, and enjoy the new functionality!
StephenW
23-Emerald II
Thanks Matthew Ender. I think you have gotten it right. Having the option makes sense and having it default to "expected" process is best.
olivierlp
Community Manager
Status changed to: Archived
