Regen_Modified_Objects_Only
Regeneration is important. But...
Currently, when we hit Ctrl + G in an assembly, it will regen every single parts (regardless of repeat items), regardless if the parts have been modified (check it in the message log).
It will not make any difference if the assembly are below 100 items.
But in a main assembly with lots of sub-assemblies and repeated components, it will be waiting ... and waiting...
Would be very much appreciated if we have this option so that only modified parts or relocated components need to be regen.
Thank you
2 Comments
Trebla
Hi Eileen, you could use this config.pro option: regenerate_read_only_objects no
EileenTung
6-Contributor
Hi Trebla, thank you for the recommendation.
I had tried out. It works well for components had been "Locked" in the workspace.
But for those "Not Locked" and no modification, it will be regen again.
Another option to work faster.
Thanks.
