I wish that Creo retained the last ‘user entered’ value or choice. Not always defaulting back to whatever the default is. Welds, point placements, hole sizes, flange lengths, etc.. (Mind you, there is one or two variables that do get kept, but these are minor ones). If I’m laying down a bunch of welds, each & every time I pick the weld to lay, I have to re-enter the size, length, depth, shape, etc.. Yes, I can pick it from the list, but each & every time, 4 variables to pick; 8 clicks.., And I’ve got about 5 welds per corner of my octagon welded box..
I’m laying out a few flanges (or flats). It would be nice that the length of the flange remain constant, so I don’t have to change the length each & every time (and why is it always some weird length?!)
I’m dropping a bunch of holes onto my part. They are all ¼-20 tapped, 3/8" deep. But each hole requires (like above) that I pick & click the size I want.. Again, I selected "tapped hole, ¼-20".. Remember it till I need to change it to something else (I’m going to change it for a different hole anyways..) Just make it so I can place it & move on to the next one..
