Remove Inch Sign from Length Callout of a Threaded Hole Created With Machining Command
In Creo Elements/Direct (CoCreate) when using the <Length> text reference in the callout of a threaded hole created using the Machining command the dimension is followed by an inch symbol (") when a Unified Thread (inch) is used.  Proper practice is that if the drawing is made in inch units that no symbol is given.  It is not currently possible to remove the inch symbol from the length text reference.
1 Comment
Community Manager
Status changed to: Archived
