There should be an option to allow files to be saved without a version number by default.
Ie. A.prt.1 becomes just A.prt
Update: To clarify, this would allow end users to use existing Version Control Software such as git to manage the files.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS130154
refer to this article, this functionality is available in Creo 3.0 by setting config.pro option save_file_interations to no
Yikes, that option is going in our config.sup as YES as soon as I deploy Creo 3.
I guess it's good to have options but next someone will ask for some automatic backup system since that is what the iterations do for you.
