Please remove the 80 Character barrier/limit in STRING Parameters. If a String Parameter is allowed to be entered in PDMLink then it should be able to be as long as required. Also Word Wrapping in Tables allows for longer text to be effectively entered but now the limiting factor is the 80 characters that is a max in Parameters.
