The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Removing Component Names (from ECAD_REF_DES column) by using the NAMES menu in MODEL PROPERTIES, should also remove the REF DES LABEL note
currently, removing Component Names (from ECAD_REF_DES column) by using the NAMES menu in MODEL PROPERTIES, does not remove the REF DES LABEL note. Since the note is just an annotation method to show the name, it should not be there when the names are removed. Users are forgetting to remove the note after removing the names are are confused why it still shows when they are showing the reference designators.
This is in reference to case 12958332.
2 Comments
JimBarrettSmith
olivierlp
Community Manager
Status changed to: Archived
