Rending in Draft quality should use white Background.
Back in Pro/E, it was easy to make a rendered picture to put in a document. As the Backgrund by default was white.
The quality of this often did not need to be high, but just remove all datum (base) plan and cosmetic skecth and make the part look smooth.
Know that the Background color is black, you can not just copy it over too an document, but need to use time setting up an scene and ligtning.
Also the back color ofent make it harder to see the parts/details comparede to the white backgrund.
2 Comments
Brokholm
Hi
All Futur Creo product that Have Rendering.
PTC have added a lot of enhancment to the render sincen changing name from Pro/E to Creo. A lot of them are good, but unfortunate the possiblity to make a fast render to make a screen shoort to put in you design document or share whit a colleague is gone because of it.
So i would not assosiat it whit a certain version, but more as a general change/add to make wenn possibel... Hope it answer your question.
olivierlp
Community Manager
Status changed to: Archived
