Back in Pro/E, it was easy to make a rendered picture to put in a document. As the Backgrund by default was white.
The quality of this often did not need to be high, but just remove all datum (base) plan and cosmetic skecth and make the part look smooth.
Know that the Background color is black, you can not just copy it over too an document, but need to use time setting up an scene and ligtning.
Also the back color ofent make it harder to see the parts/details comparede to the white backgrund.
