Repeat Regions - Blanking or Hiding Cells
0 Kudos
I have a couple ideas for hiding text within a Repeat Region Cell.
  • Idea 1:  You can write a relation to hide individual cells, but you can only hide one cell using the exact value within that cell, and you cannot use wildcards in a repeat region relation to blank all cells containing a certain set of text strings to blank.  Is it possible to add wildcard ability to the repeat region relations so that you could blank all of the cells containing a certain string of text.
  • Idea 2:  Is it possible to make it so that you can change the text color of individual cells within a repeat region, currently when you change the color of text within a repeat region, all of the text within that column changes.  This could be a good way to blank off or hide individual text when creating .pdf of drawings or printing drawings.  This was a setting we had with our printers and .pdf files for Creo Direct that a certain user defined color would not print in a print or in the .pdf.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
