Repeat Regions in a Template should be configurable to a Template View using a non-default REP
Currently, Drawing Template Views can use specific simplified Reps. However, any repeat region table placed in the template ONLY use the master rep. If you try creating a drawing with such a template where the view is set to show balloons, an error appears since the table is for the master rep, not the view rep.
Please allow the table to be configurable in such a way where it can be linked up to a template view or specific rep.
Thank you.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
