Replace All for drawing format
Currently drawing formats need to be replaced one by one.  Multiple sheets can be selected so they all appear in the setup window, but each sheet still needs to be selected one by one for the format to be changed.
Add an option to be able to select multiple sheets and "Replace All".
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
  • Manufacturing
  • Windchill / Creo Admin
  • Engineers
2. What version of Creo Parametric are you currently running?
  • Creo 7.0.4.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
  • Having to update the formats across on a drawing one sheet at a time
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
  • faster updating of legacy drawings to current standard
1 Comment
olivierlp
Community Manager
Hello @mkron,
Thank you for your idea. We are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up. To facilitate more engagement on your idea, I would recommend that you add more details and context to the minimum you already provided. here is an example of a well documented idea for Creo Parametric.
