There are times when I have a component in an assembly and I realize that component should have been an assembly instead. This most often happens when I need to add pins to the part or something small like that. Starting with Wildfire 5 there was an enhancement made so that if a part is duplicated it could be replaced using the unrelated component and evaluation rules.
I would suggest that these rules be updated to look for a component within an assembly. If the component being replaced exists within the assembly that you are replacing the component with, the entity IDs should be able to be auto paired.
Said another way:
Item to be replaced: Component_A.prt
Item replacing it: SubAssembly_B.asm
If assembly contains component A:
SubAssembly_B.asm
-Component_A.prt
-Component_C.prt
Then auto pair / update the entity IDs.
