Replace sketch entity - chain to chain or chain to entity
I would like to select more then ONE entity and select Replace function (RMB) = chain to chain, chain to entity or entity to chain.
At this time it is possible use Replace function only for One entity to another (one to one) - in sketch mode.
4 Comments
danderson
11-Garnet
Or latest allow the command to remain active until we hit the escape button or enter.  This would prevent us from having to continually execute the replace command for each sketch entity that we want to replace and would speed up the process.
kdirth
20-Turquoise
Replacing a chain with a chain would be problematic in trying to get the each entity replaced by the correct replacement.  However, to build on Don's idea, a replacement button in the ribbon that would stay active until you are done replacing would be a great enhancement.  It could work similar to the other sketching tools, remaining active until the middle mouse button is pushed.
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
