Reproduction of part color in drawing
I would like to have a feature that would allow colors assigned to a part/assembly to appear in the 2D drawing. This would be helpful for clients to see parts that are part of a large assembly, which might otherwise be difficult to spot in a 2 D Black and white drawing. Thanks !
Cheers,
Avinash
8 Comments
Dale_Rosema
22-Sapphire I
Sai Avinash Revanur
You may want to vote on your own idea....
WayneSchrock
Does "Colors come from" option do what you want? If not you way want to add more detail.
srevanur
1-Newbie
Awesome Wayne Schrock‌! You helped me solve an issue which the product support wasn't able to accomplish! Thanks a lot!
Dale_Rosema
22-Sapphire I
Toby Metcalf
Current functionality?
AmitDeshpande
18-Opal
You can show the color of the model also by displaying the drawing view in Shaded display.
The Model:
The Drawing:
Amit
Tmetcalf
Emeritus
Thanks for bringing this to our attentionDale Rosema‌ and the answer Amit Deshpande
Best,
Toby
srevanur
1-Newbie
Does anyone know how to set the "Colors come from" property to "model" as default? What is the name given to it in the .dtl file?
StephenWilliams
22-Sapphire III
Although it seems like it would be a simple option, I don't believe they have that option in the drawing setup or the config.pro.
I personally wouldn't use it except in a few rare cases due to the fact that my plotter pen widths are based on colors and that would make a mess of my drawings. But it seems like a valid option to have.
Maybe that would be the product idea you should submit...Add the option to set colors from model in the drawing as default.
