Restore drawing Show/Erase functionality in order to search all non-displayed dimensions (erased or deleted)
Please vote to restore the ability to show any annotation (dims, notes, axis, etc) on a drawing that is not currently being shown (whether erased or deleted) using a single interface such as the show dialog (or show/erase dialog in WF4).
Currently Creo2 only allows the user to show all "deleted" annotations or those that have not yet been shown.  It does not allow the user to show all erased annotations, as was the functionality in ProE wf4.
More details if want to keep reading:
There is no acceptable workaround to this loss of functionality.  The Dwg tree has its uses, but the user should not have to rummage through dozens or even hundreds of annotations to find the hidden one(s) that they need simply because the show dialog does not show erased dimensions as it used to.
This comes up in 2 frequently occurring cases:
  1. User erased a dimension and now needs to restore it
    (which is now buried somewhere in the drawing tree, requiring the user to manually click on every erased dimension to see if it is the one they are looking for).
  2. User wants to verify that a part is fully dimensioned according to the model
    (in ProE this was done simply by showing all hidden dims, which show up in a different color, and then the user can easily and quickly make sure that the ones that need to be represented are).
In short, this change from WF4 to Creo is a destruction of the efficient show/erase tool, and the 'workaround' is incredibly inefficient and is an abuse of the drawing tree.
Update: Even though we have been on Creo for almost a year, I still get questions like, why can't I find this dimension or axis?  Answer? Perhaps I should tell them that PTC doesn't want you to find it so they hid it in the dwg tree so well that users, the find tool, and the show tool can't find it. Most perplexing is that PTC introduced (broke) this "feature" in WF5, and we are now on Creo3, years later, and it is still not fixed?!?  Maybe in Creo4?
10 Comments
lscheeler
If someone only wanted to show deleted/never shown annotations, a simple and easy way to do this would be to add a check box to the Show Model Annotations dialog that could be checked by default:
E.g.  "Include Erased dims" in results
lscheeler
korr
Another related idea: how about erase all by view. Recently I made a drawig of a sub-assy where all the parts had sets datums (A, B, C & GD&T). I had to pick each one individually to remove them from EACH view. Prior to Creo series, there was an "erase from view" option. Where did it go.
lscheeler
Agreed.  A coworker recently rehashed this problem and expressed how annoyed he was at loosing this functionality that he frequently must use.  Now he is left with erasing/deleting the individually, or selecting the selection type and box around them.  Neither are very time efficient options.
Show Erase dialog was beautiful: easy to use, simple, and fast.  It completely boggles/blows my mind first why it was ever removed, and 2nd why it is taking so many years to fix (They broke this back in WF5!)!
ssircar
Fully agree. We are having lot of issues with this lost functionality.
We cannot migrate to Creo2 from Wildfire4 because our mapkeys to create dxf files use this functionality.
ssircar
I would further like to add that this case is very similar to the functionality of creating co-ordinates by offset/rotate/etc. along any axis or a combination of axes, which was taken away in Wildfire. That functionality was very useful in controlling movements only in specified directions/planes. Now, the user is prompted with all degrees of freedom along all axes and the possibility of error is high!!
PTC should not be taking away functionalities just like that !!
lscheeler
Welcome to the forums Shailendra,
Your mapkeys use the show/erase dialog to create dxf files?  If so, what is the reason for that?
TomU
23-Emerald II
One thing that helps some is forcing Creo to automatically delete all previously erased axes and dimensions.  This way when you use the show model annotations functionality they will once again be listed.
Add these lines to your config.supfile (must be in the loadpoint)
! === Drawing update commands - must be listed in this order ===
enable_auto_drawing_update yes
auto_drawing_update_command delete_erased_axes
auto_drawing_update_command delete_erased_dimensions
See these articles for more info:
PTCModerator
Emeritus
mdewet
6-Contributor
I have a similar problem, but instead of dimensions, it has to do with Balloon Notes in drawings - See Product Idea
