Restricted Parameter values selectable from drop-down listboxes in the "New File Options" dialog.
2020-06-11_11-42-53.pngWould've thought we'd have this by 7.0.  Guess not.
1 Comment
MikkoHinkkanen
I would not suggest using restricted parametes list at all. Maby for PTC internal attributes used for piping and NC, but otherwise not.
Reason for this is the update steps required, should lists change over the years. Second reason is, that one cant make selection list which is dependable on previous value selected.
This use case can be solved by using CAD application which manages parameters, handles templates, etc.
