If I have an assembly with several patterns of washers, screws & nuts and then I decide I need to create a sub-assembly and that sub-assembly contains some of those patterns of nuts, screws & washers, at present I have to delete each pattern, Restructure and pattern again.**
The idea is to allow restructuring of patterns of components, without having to delete the pattern first.
**This is the case in WF4, M220 - maybe it's fixed in CP2, I don't know.
John
