When a thead features are placed in bend area of large bends, they will not be automatically revalidated by the system.
When one wants to revalidatie (select feature, modify) it is difficult to replace the center point with the correct position.
Since the geometry of the thread feature holds no circles anymore. One needs extrs steps to find that new position.
Also misclicking is easy and it will lead to several lsp errors
Would it be possible to have this validation done automatically ? Somewhere in te routine during the unfold the centerpoint in the unfolded plate is chosen, so why not use that, and the new face's direction for revalidating that feature ?
