Review feature mirror functionnality
The actual mirror function in Creo Parametric is so bad, we cannot edit the contain to add or remove feature, if you mirror a pattern and then edit a dimension of the  internal feature the change won't be propagate into the mirror feature. Seriously If I decide that I need to mirror a feature is because I need the mirror to be the exactely the same.... you really need to review that functionnality quickly it's definetly a lack of efficiency in this CAD tool.
8 Comments
rsobecki
I agree the mirror of the feature must be reviewed and updated but if you will use geometry - you'll be happy
ptc-5589582
1-Newbie
FYI: Martin, you can vote for your own idea.
ptc-6475852
1-Newbie
I also agree the mirror function is outdated and needs to be reviewed to make more productive.
MikkoHinkkanen
Pour some resources to mirror feat.
StephenW
23-Emerald I
It may or may not be what you are looking for but Creo 4 (M020) is supposed to improve the mirror feature and mirror in assembly.
Maybe there is hope. (screen grabs from the Creo 4 presentations)
Introducing Creo 4.0
Creo 4.0: See What's New in Creo Parametric
MartinStLo
7-Bedrock
Thanks for the comments Stephen!
This is a good news...
Be able to add & remove feature from the mirror was the minimum we can hope from a mirror function and finally it seems that the hope will end at M020...
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
