Review feature mirror functionnality
The actual mirror function in Creo Parametric is so bad, we cannot edit the contain to add or remove feature, if you mirror a pattern and then edit a dimension of the  internal feature the change won't be propagate into the mirror feature. Seriously If I decide that I need to mirror a feature is because I need the mirror to be the exactely the same.... you really need to review that functionnality quickly it's definetly a lack of efficiency in this CAD tool.
7 Comments
rsobecki
Amethyst
I agree the mirror of the feature must be reviewed and updated but if you will use geometry - you'll be happy
ptc-5589582
Newbie
FYI: Martin, you can vote for your own idea.
ptc-6475852
Newbie
I also agree the mirror function is outdated and needs to be reviewed to make more productive.
MikkoHinkkanen
Amethyst
Pour some resources to mirror feat.
StephenWilliams
Sapphire II
It may or may not be what you are looking for but Creo 4 (M020) is supposed to improve the mirror feature and mirror in assembly.
Maybe there is hope. (screen grabs from the Creo 4 presentations)
Introducing Creo 4.0
Creo 4.0: See What's New in Creo Parametric
MartinStLo
Regular Member
Thanks for the comments Stephen!
This is a good news...
Be able to add & remove feature from the mirror was the minimum we can hope from a mirror function and finally it seems that the hope will end at M020...
PTCModerator
Topaz I
