The actual mirror function in Creo Parametric is so bad, we cannot edit the contain to add or remove feature, if you mirror a pattern and then edit a dimension of the internal feature the change won't be propagate into the mirror feature. Seriously If I decide that I need to mirror a feature is because I need the mirror to be the exactely the same.... you really need to review that functionnality quickly it's definetly a lack of efficiency in this CAD tool.
