For the creation of a revolve (over 360°) we used the option to select twice up to the sketch plane as an option.
This generation method has the advantage for us that no angle dimension 360° is displayed when showing the dimensions.
Now the product specification has been changed and this generation method is no longer supported. It is not even possible to select two different planes that represent different angles. This can be read in the CS296387.
This is especially unpleasant because the generation method must still be supported for existing models. Only a new generation is no longer possible.
Please vote for the fact that the creation of revolve with the option "to selected" supports two datum planes!
