Right-Click Work Offline/Online
Today in Creo Parametric 2.0 in your list of Common Folders it lists your "In Session", WIndchill Cabinets, Workspace, etc.
If you're working offline you have to go File, Manage Session, Server Management, Right click on the server and uncheck the "Work Offline" option.
It would be nice if you could activate this menu through right-click in the common folders menu. At least work offline option, It already knows your active server. It could also call this server management window and maybe even the steps to register a new server since this is an existing right-click option in Server Management Window. It would be even nicer if it showed all your servers in Common Folders, though I could see that causing some confusion too.
Here's a mock up example of what I'd like to see:
I haven't checked out Creo 3 yet.
2 Comments
sully7
Similar to this: http://communities.ptc.com/ideas/4600 for availability to see if you are offline in the API.
PTCModerator
Emeritus
Status changed to: Archived
