Round Real Number parameters to use in symbol
There is no possibility to round a parameter that is used in a variable in a symbol.
It would be beneficial to have a possibility to display a rounded parameter without using the brackets [.2] or the workaround with a seperate relation to calculate a rounded version of the parameter.
3 Comments
BenLoosli
23-Emerald II
How do you propose that a number be declared to be .xx decimal places?
Suggestions work better when a solution is proposed with the request, rather than just saying you want something changed with no validation by reason or solution.
The [.X] works great as it allows you to designate the decimal places at the where used point and still maintain fill floating precision value in the database.
J.Wagner
9-Granite
Hi Ben,
I'm not pretty sure about how this can be solved.
Using the [.x] is fine for me, when I use the parameter in notes.
But when you want to use the parameter as a value in a symbol variable, then you can't use the [.x]. That's what we need the round of the parameter for. Maybe a general DTL option for rounding parameters in symbols would be a possible solution.
Kind regards
Jens
BenLoosli
23-Emerald II
I voted for this change based on your explanation of a variable in a symbol.
Please vote up your own idea.
