Currently when you have several combined states and different simplified representation in each one of these, only the simplified representation activated during the STEP AP242 export is saved.
So when you open the STEP AP242 there is the same simplified representation (the one activated during the export) in each combined state.
Creo should export correctly simplified representation (for a .Prt AND an .Asm) on combined states with a STEP AP242 export.
