When you export a 3D model in a STEP format from Creo, it's possible to parameter data exported by using the step_profile_export file (see photo attached)
It works correctly on Creo Parametric but when you use a CAD Worker, the step_profile_export file is not supported ! So it's impossible to choose which type of data(annotations, datums, ...) should be exported with the use of a CAD Worker.
This is a problem hinder for a company (using CAD Worker) which want to use the Model Based Definition and thus archive STEP AP242 model with 3D annotations.
