Saving a paginated table to a CSV file should grab the whole table (not just the paginated segment)
If you ask 95% of users that they want to export a paginated table to a CSV file, they will tell you they want it all, not just one paginated segment.  this should be the default option. (or at least give us a config to allow us to save the full table as if it is unpaginated i.e. without headers and footers)
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. We need more information as specified in the form you saw in the submission process. (Questions below). The more details and context you give, the better.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
PetePickettII
1. END USER/SUPER USER -   MARINE INDUSTRY, WIRE AND HARNESSING FOR BOATS
2. CREO 8
3. WE NEED TO DROP LARGE TABLES OF BOM AND WIRE CUTLISTS TO CSV FILES.  SOME OF THOSE TABLES HAVE COMMENT CELLS WITH USER DATA.
4. DROPPING A WIRELIST TABLE TO A CSV ALLOWS THE MFG TO USE THE EXCEL FILE TO BUILD CUTLISTS.  UNFORTUNATELY, THE CURRENT FUNCTIONALITY ONLY SAVES A PORTION OF THE PAGINATED  TABLE THAT MIGHT HAVE UP TO 150 LINES.
5. IF YOU ASK ANY LAY PERAON, THEY WOULD ASSUME THAT THE CSV FILE WOULD DROP THE WHOLE TABLE AND NOT A PAGINATION SEGMENT.
olivierlp
Community Manager
Thank you for your idea and the information provided.
