Schedule and queue generative design studies
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Space industry, Mechanical team lead. My group / colleagues
2. What version of Creo Parametric are you currently running?
9.0.2.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We run generative design on our local machines. It would be nice to be able to add multiple design studies in a queue both structure and modal types, with different design criteria. For example through a drop down option for "Optimize now" or "Queue optimization" Then, when ready, click a button to start processing them. One should then also be able to choose to either process them sequentially or in parallel. This way one could set up multiple studies with varying parameters and set it to process over night.
4. What is the use case for your organization?
Shorter time to reach final solution.
5. What business value would your suggestion represent for your organization?
Able to produce more optimized designs.
1 Comment
olivierlp
Community Manager
Thank you @ErikClacey for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
