Screw check function
we can define screw and threaded hole by "Machining" command.
If screw is larger than threaded hole (i.e.M8 screw and M6 hole ),
“clash” command is detected as clash. It’s OK.
But if screw is smaller than threaded hole (i.e.M6 screw and M8 hole ), “clash” command is not detected. I would like to check both situations.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
