The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Searching for parameter vaules in subassemblys without adding them to the internal memory
Our customer works in very large assembleys. In order to open these they have created a simp rep that opens the model without any geomtry loaded. When a model is opened with this simprep Creo only add the top assembly to it´s internal memory.
However when performing a search for parameter values Creo adds models to the internal memory causing a crash and exit.
The search is performed from Tools>Find
Look for: Solid model/Solid model
Look in: top assembly
Rules: Expression
Options: Not retrived
It would be nice to be able to search in the submodels without adding them to the internal memory if possible?
3 Comments
Dale_Rosema
23-Emerald II
You may want to vote on your own idea....
.... and on this one too.
http://communities.ptc.com/ideas/2713
Thanks, Dale
NilsP
3-Visitor
Haha. Thanks Dale! You have my vote.
PTCModerator
Emeritus
Status changed to: Archived
