Section failure
Section failure
The visualization of a  section of a simple assemblage in onedrawings is wrong.
  Example below shows perfectly problems of graphic presentation in a drawings.
because of model complexity (Often linked to accuracy problems) make the section failing randomly.
as a workaround is to bring forward the plan of 0,1 mm cup.  In that case simple is ok ,but this resolution cannot be applied on all  projects
It will be good to have  tools to improve model checking and essentially Accuracy management.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
