I would like to have a tree column option to see drafts and rounds values. Sometimes I have multiple parts that I want to match the order and values. Instead of clicking each draft or rounds, it would be nice to see the value of them next to the feature.
For example Round 1 : R0.5 mm or Draft: 5 deg
I understand you can make several sets of different value rounds or have variable rounds, in this case the tree column value could just be empty.
