The save_texture_with_model configuration option controls whether images are embedded in models and drawings.
It would be useful for us to have separate options for 3D models and 2D drawings, for example:
save_texture_with_3d - Controls whether images are embedded in 3D models
save_texture_with_2d - Controls whether images are embedded in 2D drawings
The reason for this is that we have 2 different use-cases:
3D Models - Typically textures/decals from a library that are used across many different models
2D Drawings - Typically images that are specific to that particular drawing
Tim
