Set Symbol M for standard hole - no diameter symbol
If I create Standard hole (Iso Hole - ...M8, M10, M12, etc.) system automatically create diameter symbol for dimension. Then, if I use Show dimensions in drawing mode - I have to find all Standard hole and change manualy main dimension to symbol M (inside dimension you can hide - it is not necessary show this information):
4 Comments
TomD.inPDX
This falls right in line with simplified formatting of thread notes.
lbono1
i think the the correct way is use the screw_size in the text of the diameter dimension
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
