Set default tolerance by a tolerance table in EZTol
In EZtol option setting, software allow user to set a default tolerance value for the dimensions that are not link to 3D annotation. But in reality, the default tolerance value for dimensions should be different. The default tolerance of dimensions  depends on the length  of the dimension just like using a tolerance table. So it would be good to have a function to let user import a tolerance table in EZtol stack-up UI.
