currently if a shaded views is section in annotation, the clipped faces appear in some system default color. This should actually be able to be set to the part color. The whole purpose of creating shaded views in annotation is for clarity.
Normal shaded views, the parts are shown in the actual part color. however; when a cutaway or seciton is added, the clipped faces change to a default color making the shaded view pretty useless.
